Any help on welding frame for go-kart? A buddy has a son with a hotrod go- kart and they want to put a different engine in it and they need one of the cross bars moved. I have welded many years but never chrome moly. Any help would be good!!!
Chrome Moly tube welding?
Chrome Moly welding?
Hey i'm looking for some info on welding chrome moly tubing. My buddies' son has a go kart and they want to put a bigger engine on it so they need to move one of the cross bars. I have been welding for quite a few years but mainly on things quite a bit larger( D-8, D-9, ect.) I have a Trailblazer 302 w/ 12 RC wire feeder and a Dynasty 200 DX. Need to know the best process and what wire or filler metal to use. Thanks...
Originally posted by ROD BURNER View PostHey i'm looking for some info on welding chrome moly tubing. My buddies' son has a go kart and they want to put a bigger engine on it so they need to move one of the cross bars. I have been welding for quite a few years but mainly on things quite a bit larger( D-8, D-9, ect.) I have a Trailblazer 302 w/ 12 RC wire feeder and a Dynasty 200 DX. Need to know the best process and what wire or filler metal to use. Thanks...
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
Originally posted by MAC702 View PostI read on the Internet somewhere that you should weld it with oxy-acetylene..."Better Metalworking Through Research"
Miller Spot Welder
One thing to keep in mind, on a Kart the suspension is the flex in the frame. In the wet, most of the bracing comes off, on a high grip track bracing goes on.
If you are changing cross bars, that part needs to stay in line, engine and axle sprockets that is.
Keep an eye on the welds when you are running it, the frames move and twist a lot on the track, especially in high g turns.
So what are you changing from, to?
Originally posted by ROD BURNER View PostAny help on welding frame for go-kart? A buddy has a son with a hotrod go- kart and they want to put a different engine in it and they need one of the cross bars moved. I have welded many years but never chrome moly. Any help would be good!!!
Just my $.02Be safe
Jeff
Give more than you get and
you will get more than ya need.
This is true for the good and bad
that life puts out.
Being "easy to weld" has different meanings to the guy doing the welding, and the guy doing the engineering. Often times the "ease" of welding by the weldor, is falsely interpurted as geing easily welded from an engineering point of view. From a weldors point of view, 2024 aluminum is easily welded, and beautiful looking welds quite common. Unfortunately they arent worth a darn as is to the engineer."Better Metalworking Through Research"
Miller Spot Welder
Yep,
I'd just get the old 302 Trailblazer out, hook up my 30 Amp spoolgun, and mig that dang old chrome molly. Nuthin to it a little practice won't fix.Syncrowave 250 DX Tigrunner
Dynasty 200 DX
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Originally posted by SundownIII View PostYep,
I'd just get the old 302 Trailblazer out, hook up my 30 Amp spoolgun, and mig that dang old chrome molly. Nuthin to it a little practice won't fix.Voigt Precision Welding, Inc.
Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
2007 Silverado 2500HD (tow vehicle)
2000 Camaro SS (Race car)
sigpic
