If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Hi All,
We are doing a custom job for a resturant and need to hang 5 panels which will overlap each other by about 1'. It's more of an artistic piece then functional. I attached a .pdf 2D drawing. I am having a dilemma on deciding the gauge (20GA...to much weight>). of cold rolled I want to use as they will be sprayed with automotive paint.
The plan was to mount them to a 1" x 1/2" sub-frame because they need to remain as low-profile as possible. I would put an "L" bend at the top of each to rest on one of the crossbars in the sub-frame. Any idea on this would be appreciated.
