I have been reading some of the posts on the Miller 180 vs the Hobart 210. Leaning toward the Hobart due to the higher top end. Going to purchase a spoolgun when I order the welder. Here's is my question, both of the spoolguns the Miller spoolmate 100 and the Hobart DP-3035 both look the same. Is one better than the other. Which one is the beefer of the two.
Spoolguns
The biggest difference is the way they hook up. The 3035 hooks up via a lug for the hot wire, the hose and the pin connector on the front panel. The spoolmate 100 hooks up where the gun was. You have to remove the whole gun assembly and replace it with the spoolgun hookup. Prob about the same amount of time for both to hook up. The biggest difference is you can leave the 3035 hooked up all the time. The guns are almost the same, and most of the parts numbers match each one.
The Iron Man 210 should have the lug like my MM185.
The Handler 210 you have to remove the gun. Forgot there are two 210's...BobLast edited by aametalmaster; 05-19-2008, 06:26 PM.Bob Wright
I wondered the same thing since i paid over 400 bucks for mine 8 years ago...BobBob Wright
Yup. You put it in better words Mac. I did forget there was 2 welders with the same number...BobBob Wright
Took the time to really read the difference between the Miller and Hobart spoolguns. Looks like the Miller comes with a 12 foot gun and Hobart comes with a 20 foot gun. Thats a pretty big difference in length. Still leaning toward the Hobart 210 Handler with a spoolgun. Looks like more for the money..Any thoughts...Miller Dialarc HF
Millermatic 180
Warner Swasey #3
Burr King Grinders
Mac, Spoolmate 100, not 3035. Smaller, cheaper gun.
I'd go with the HH210/sg. Go for the biggest unit you can afford. You can turn down the 210, but you can't turn up the 180 over...180.Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
Originally posted by gearhead View PostStill leaning toward the Hobart 210 Handler with a spoolgun. Looks like more for the money..Any thoughts...Bob Wright
I went into the local Miller shop and talked to the sales rep about the Miller 180 VS Hobart 210. The sale rep stated I should go with the Miller do to heavier internals. We talked about the possible need for the 210's extra power and I was told the 180 was enough to do all the jobs the 210 was capable of doing. Still think the 210 is the way to go on this, just as it was stated you can turn a 210 down if you need to, but you can't turn a 180 up...Miller Dialarc HF
Millermatic 180
Warner Swasey #3
Burr King Grinders
Originally posted by gearhead View PostI went into the local Miller shop and talked to the sales rep about the Miller 180 VS Hobart 210. The sale rep stated I should go with the Miller do to heavier internals. We talked about the possible need for the 210's extra power and I was told the 180 was enough to do all the jobs the 210 was capable of doing. Still think the 210 is the way to go on this, just as it was stated you can turn a 210 down if you need to, but you can't turn a 180 up...Millermatic Passport Plus
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12VS
Dynasty 300 DX
Thermal Arc 400 MST
Premier Power Welder for my trail junk.
I have used my HH210 on some very heavy stuff and had no issues. It will just about keep up with the MM210 and will weld smoother in most cases. I ran my MM and HH side by side. When I want to weld something, I'll usually reach for the HH first...sorry Miller.So, since this HH is amost keeping up with the MM210, I really doubt the MM180 would keep up with the HH. If you get the HH, you will not be unhappy.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
Originally posted by DDA52 View PostMac, Spoolmate 100, not 3035. Smaller, cheaper gun...
